Victor Charles
Help with viewing images in an MSReport using a Dataset using VB.NET
I'm using the code below to view images whose file names are in my xml file and the images are listed in my application's folder, but I'm unable to view the images. How do I solve this issue?
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Dim ds = New DataSet()
ds.ReadXml(Application.Sta rtupPath + "\linkSearch.xml")
ds.WriteXmlSchema(Applicat ion.Startu pPath + "\linkSearch.xsd")
Dim curfile As String = (Application.StartupPath + "\linkSearch.xml")
fslinkBEL = New System.IO.FileStream(Appli cation.Sta rtupPath + "\LinkSearch.xml", IO.FileMode.Open)
dtsetlinkBEL.Clear()
dtsetlinkBEL.ReadXml(fslin kBEL)
fslinkBEL.Close()
Dim FilteredDT As DataTable
Dim DV As New DataView(dtsetlinkBEL.Tabl es(0), Nothing, Nothing, DataViewRowState.CurrentRo ws)
FilteredDT = DV.ToTable
If FilteredDT.Rows.Count > 0 Then
Dim reportDataSource As New Microsoft.Reporting.WinFor ms.ReportD ataSource( )
reportDataSource.Name = "DataSet1"
reportDataSource.Value = FilteredDT
ReportViewer1.LocalReport. DataSource s.Clear()
ReportViewer1.LocalReport. DataSource s.Add(repo rtDataSour ce)
ReportViewer1.LocalReport. Refresh()
ReportViewer1.RefreshRepor t()
End If
End Sub
Victor
fslinkBEL.Close()
End If
End Sub
Victor
I dont see any code related to image or path...
The image is connected to the image field in the rdlc file.
but it is not an image! it is just path to the image...
so I believe you need to set the path/src of image correctly
if path in db is "image1.jpg", and images are stored in "pictures" folder on your server,
maybe you should set the src of image as "http://domain_or_server/pictures/image1.jpg"
I can't hard code tne image names because as I move to each revord I need to see whatever image is in the xml file.
This is a windows apication, need to set path to application's folder without hard coding name of the images.
Thanks.
Thanks.
ok then you need to write some code and say
image.path = app.path + ds["imgPath"]
or loop all records in FilteredDT and change path to app.path + ds["imgPath"] before binding to report...
or something like that... I dont think db has full path to file...
Image.path? How do you declare image before using it in the code?
after this line
you can change the values
for each row in FilteredDT.rows row.imgPath=app.path & row.imgPath
then bind it to report...
Thanks, I will try it when I get home. Shouldn't the code include the "Image" field which contains the images' names?
I tried your suggestion as shown in code below but getting error message:
An unhandled exception of type 'System.MissingMemberExcep tion' occurred in Microsoft.VisualBasic.dll
Additional information: Public member 'imgPath' on type 'DataRow' not found.
On line: row.imgPath=app.path & row.imgPath
For each row in FilteredDT.rows
End If
Next
End If
Next
I gave you pseudo code, not exact code!
path of app can be retrieved like this
then for each row change the value before binding
and replace imgPath with your column name...
by the way,
where are your images
how are they stored in db
what column stores those values?
dim path As String = System.IO.Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().GetName().CodeBase)
ordim path As String = Application.StartupPath()
ordim path As String = Application.ExecutablePath()
row("imgPath").value=path & row("imgPath").value
by the way,
The images are in my application folder in an image subfolder. The image names are in my xml file (Image data element) which was converted to .xsd to include in the project. I will try your code and get back to you.
Thanks.
Thanks.
so, this should work
row("Image").value=path & "image\" & row("Image").value
Unfortunately it did not work. I received error message:
Additional information: Public member 'value' on type 'String' not found.
On line:
row("Image").value = path & "Image\" & row("Image").value
code:
fslinkBEL.Close()
MsgBox(FilteredDT.Rows.Cou nt)
Dim path As String = Application.ExecutablePath ()
For Each row In FilteredDT.Rows
End If
Next
On line:
code:
fslinkBEL.Close()
End If
Next
then dont use value!
row("Image") = path & "Image\" & row("Image")
Below is the code and xml file containing the images for your information, hopefully you can duplicate the project from your end and test it with an image file. I am not able to upload the load the project.
Public Class Form1
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
Me.ReportViewer1.RefreshRe port()
End Sub
Private Sub ReportViewer1_Load(sender As Object, e As EventArgs)
End Sub
Public fslinkBEL As System.IO.FileStream
Public dtsetlinkBEL As New DataSet
fslinkBEL.Close()
End If
Next
End Sub
End Class
LinkSearch.xml
<?xml version="1.0" encoding="utf-8"?>
<Root>
<MyDataTable>
<LinkAID>1</LinkAID>
<Image>ImageA.jpg</Image>
</MyDataTable>
<MyDataTable>
<LinkAID>2</LinkAID>
<Image>ImageB.jpg</Image>
</MyDataTable>
<MyDataTable>
<LinkAID>3</LinkAID>
<Image>ImageC.jpg</Image>
</MyDataTable>
<MyDataTable>
<LinkAID>4</LinkAID>
<Image>ImageD.jpg</Image>
</MyDataTable>
</Root>
forms.pptx
Public Class Form1
End Sub
End Sub
fslinkBEL.Close()
End If
Next
End Sub
End Class
LinkSearch.xml
<Root>
<MyDataTable>
</MyDataTable>
<MyDataTable>
</MyDataTable>
<MyDataTable>
</MyDataTable>
<MyDataTable>
</MyDataTable>
</Root>
forms.pptx
I tried your suggestion, no errors occurred but the images are not displayed.
then debug your app
and see what is assigned here
is that correct?
is that correct?
I am getting the wrong path
Victor
Debug\WindowsApplication2.
Victor
When I try the code below to obtain the correct path, the images are still not displayed.
Dim path As String = Application.StartupPath()
row("Image") = path & "\Image\" & row("Image")
try using Application.StartupPath
It still doesn't work, removed .Value to avoid the error but still doesn't work, the path is correct bu for some reason the images does not display, could it be a property needs to be set to view images?
if path is correct, then play with report parameters for image field...
Trying different things in image properties but so far no luck.
try setting this
myReport.EnableExternalIma ges=true
check this video
https://www.youtube.com/watch?v=D4uU25NUy_4
check this video
I followed the example for viewing external images, but the example is only for hard coding the external image in the code. How do I modify the code to include row (image) in the r(0)?. The code below in part B does not work, can't figure out how to include row(image) values in the following code: r(0) = New ReportParameter("ImageVar" , row("Image"), True). Code in Part A shows code in the video for hard coding an external file.
Part A:
Dim r(0) As ReportParameter
r(0) = New ReportParameter("ImageVar" , "files\" + "imagepath\image.jpg", True)
ReportViewer1.LocalReport. EnableExte rnalImages = True
ReportViewer1.LocalReport. SetParamet ers(New ReportParameter() {r(0)})
Part B
End If
Next
Victor
Part A:
Part B
End If
Next
Victor
HELP!
I think the report parameter r(0) needs to be part of the code, similar to the example, only difference is solution of for specific image, I need to pass image value for each record.
Victor
Victor
