kamran kazmi
We have an APC SURT5000XLI UPS that will not power up. It just has an illuminated Fault LED, 1 Battery Level LEDs on?
It just has an illuminated Fault LED, and the 3rd and 4th Battery Level LEDs on. See embedded image.
LEDs on front of APC UPS
Can anyone translate what its trying to say? I can't find a fault finding guide anywhere, other than 'engineer required'. Such an engineer scratched his head, and said it needed replacing...
either that or it needs a service.
I'm checked all over board i haven't seen burning and all mosfets working properly - charging section, supply section, power factor and batt. boost section all will be perfect working i found problem on control card. so any one help in this. batteries voltages are perfect. checked all batteries through load tester many time charge and discharge batteries
ok,
Whether or not you can see the issue, whether or not the battery holds charge, this is a problem for the manufacturer, this is going to be a service call to APC.
Regards
Alex
Regards
Alex
thanks
You're welcome, sorry it turned out this way.
Service required
