Gite
problem with access 2010 runtime in solution package
I have a simple access 2010 app thet I want to distribute to users who don't have access. I have windows 7.
I used the package wizard to make a package includint my mde together with access 2010 runtime.
When I install the app on the user's computer (windows 8), the access runtime does not install even though the app does.
I installed access 2010 runtime manually on that computer and applied service pack 2. It does install. However, when I click on the first button in the app, I get an error message saying it cannot use my VBA code. Yhe vba code worked on my computer, though.
What can I do?
Thanks in advance
What can I do?
Thanks in advance
Thanks a lot. It worked
Author indicated the comments worked.
I succeeded in implementing my package using the package wizard to set up the reg keys.
However, I'm now trying to imlement on a XP computer the same way, but I stil get an error message saying it cannot use my VBA code.
How do I settel that problem on XP?
Please ask this as a new question.
I checked for the references and I think there should be no problem. You wil find them attached.
I will also add the following to my solution package
My application will not be installed nor use datata in a subfolder of C:\MA not on a network. However my app will communicate from time to time with an SQL Server on a remote server. That connexion to SQL Server was tested on my machine.
Please confirm that my references do not need any specialin sht package and that those comments should solve the Trusted Center problem.
Also, I don't understand how that could explain why Acces runtime was not installed with the package, while it was included into it.
