Amir Haviv
running tcpdump or tshark with python script and arguments
Hi
i need a help of creating a script that runs tcpdump and request for arguments of ip address src and dest and port,
saves the outcome to a file
appreciate your help
Amir
Amir
OP inactive
Thank you so much
Another question, this dump will run endlessly, i need the option to put an argument of ctrl+c in order to stop the capture whenevr the user wants and then the file should be closed
How wouldni add that option?
Again
Thanks for you kind help
Amir
