Thanks Alan,
Unfortunately I cannot provide the exact resources as I've read a few forums and I'm almost lost, they are just random assumptions I've found so far, That's why I was under the impression, They could be wrong . The cables won't be CCS. I'm looking for Certified CAT6 Ethernet Patch Cable, DataMax . something like the link provided below : https://www.circamax.com/cat-6-ethernet-patch-cable-datamax-certified-black.html?category_id=26
I checked if they support 568B colour code and CAT6
Would you think of any other specs I need to consider?
Alan
For what its worth, they look okay to me, but I am not an expert.
My experience is that the cables in a patch panel are rarely the issue - it will be the switch(es), and the runs off to the wall sockets around the building that make most of the difference.
Thanks Mal,
Yes, I've read that 1M and that made me thinking, If this be a big deal to cause the network slow or probably connection drops, I would change the plan and use the longer cables, But seems it's not as important as it sounds.
