DLeaver
Ups connectivity options from hard wired connection
Hi
Can anyone confirm that if you have a ups that requires a hard wired connection that rather than go from the Ups directly to a hardware connection into the branch circuit, you can have a commando plug on the end of the cable coming from the ups terminal block? You would then have a commando socket on the wall to plug into
Thoughts?
Thoughts?
Using an electrician - we had a command socket installed and a commando plug fitted to the UPS - sorted
