I installed two app recently, I found that my battery keep draining very fast after that.
1. InkCase app (It will sync data to InkCase via bluetooth on a regularly basis)
2. SureWin!LiveMap for pokemon go (It will scan the area for active pokemon and gym)
For SureWin! app, I have disabled the notification and only allow use the location while using the app.
Can you please help test if InkCase app will keep draining my battery if it keeps running in the background and sync data to InkCase?
