Db2 DB Disk backups are running slow , CPU and Memory are normal -- need advice on AIX machine
Hi all
My Db2 DB (Disk type-Non TSM) backups are running slow.
I could see Memory is 60 percnt used and CPU is 50 % idle
I have seen disk utilization with topas and iostat but could make any concrete judgement that Disk utilization is slow.
But i have strong suspect-ion that there may be some problem with disk utilization.
It is a AIX machine.
Need some advice here
Thanks in advance!!!
Prardhan NAsked:
Tomas Helgi JohannssonCommented:
Hi!
Issue this command
db2 get db cfg for yourdb | grep UTIL_HEAP_SZ
if this size is lower than 400000 (1,6 GB) i recoomend you set it to 400000 using
db2 udpate db cfg for yourdb using UTIL_HEAP_SZ 400000
As backup, restore, redistribute, compression dictionary creatiopn and online index reorg uses this util-heap it is recommended to increase this to a high value to speed those utilities. See here for more info.
I would also recommend to split the data into multiple tablespaces and not having all tables in the same tablespace. This will speed up backup/recovery as DB2 can then use multiple threads and parallelism in the process.
Also use compress in the backup command to compress the backup ( it can speed the backup process)
Post the backup command that you use and is slow.
Regards,
    Tomas Helgi
Prardhan NAuthor Commented:
will work on inputs and come back. Thanks
Hi!
To move tables to new/other tablespaces use ADMIN_MOVE_TABLE utility.
Regards,
    Tomas Helgi
Cloud Class® Course: MCSA MCSE Windows Server 2012
This course teaches how to install and configure Windows Server 2012 R2.  It is the first step on your path to becoming a Microsoft Certified Solutions Expert (MCSE).
Ok, will work and come back.
Hi!
Any luck with speeding up the backup ?
Regards,
   Tomas Helgi
Thanks much for your help.
