sunhux
How is it controlled: while connected to corporate network, can't connect to 4G Wifi or while to corporate Wifi, can't connect to a LAN cross cable
When connecting to corporate LAN, it does not allow connection to 4G phone's Wifi & when connected to Corporate Wifi, it does not allow a LAN cable to be connected to another PC (or NAS) : how is this control implemented? Curious if this is set at GPO or local registry or ??
Oh I overlooked 1 thing: this feature is available on our Win 10 only & not Win 7:
in fact it doesn't allow both LAN & Wifi to be connected at the same time : if
LAN is connected, Wifi will show as 'Disconnected' : so where in Win10 is this feature?
https://www.umass.edu/it/support/network-abuse/disable-multiple-network-connections-turn-bridging
https://helpdeskgeek.com/how-to/bridge-network-connections-in-windows-7-8-10/
Possibly the above is what I'm looking at or are they not?
The interface connecting to public or 4G won't come up ie no IP address assigned to it
Does McAfee AV have this feature too? Basically it's preventing bridging/routing between
corporate & public networks
