I have a system that need to read data from medical device which using ASTM protocol. Is it possible to read data from the machine using php ?
chien pingAsked:
Dr. KlahnPrincipal Software EngineerCommented:
Sounds like you need to use Perl or python for this.  Both have extensive plugin libraries for both serial and network I/O and the major problems will have already been dealt with (there are numerous complaints on the web that the ASTM standard is not well adhered to in actual implementations).
http://python-astm.readthedocs.io/en/latest/protocol.html
But you might do better to just buy something off the shelf that is ready to go.  At $100/hour recharge rate for writing software, plus debugging time, even if a package costs $1000 it is cheap by comparison to making your own solution.
http://www.aggsoft.com/serial-data-logger/tutorials/astm.htm
Dave BaldwinFixer of ProblemsCommented:
It might be except that PHP normally runs on a web server.  It won't have any access to any other machine.  In particular, you can't use it to read a device from a web page on a remote machine.
chien pingAuthor Commented:
Ok, noted. Thank you for the comments.
No further input from requester.  Points split among the two participants, according to the detail of the contributions.
