Steve B
Cisco ATA 190 settings for a fax machine - having frequent problems with fax machines not negotiating
I have a Cisco UCM voip system that I am admittedly a rookie at. We recently went through a reorganization of equipment and six of our fax machines were moved to different locations within the building. We were trying to get off POTS lines anyway so we decided to purchase Cisco ATA 190 devices so that our Ricoh MFP devices could participate on the digital phone system. These installed just fine and have worked fine, or so we thought. After being on them for a month or two I am getting a lot more help desk calls stating that incoming faxes are taking forever or failing altogether. For example, I have a site that faxes here quite often. When they fax it will often times take 20 minutes to receive a fax from them successfully when the fax machine here isn't busy doing anything else and the other side is not busy either. In another instance, I had a different facility report that they could not fax to us. I happened to have the speaker turned on in that Ricoh MFP and I could hear it pick up and try to negotiate and then it would drop the call. The process would repeat dozens of times and then a fax would finally come through.
I am curious if there are any settings in the ATA 190 that I need to tweak or if there is something that needs to be tweaked in Cisco UCM for the device? Nothing in the interface on the ATA 190 sticks out at me and I don't even see a setting to lower the baud rate. I did set up the ATA to send debug messages to a syslog server so maybe that will yield something. Just looking for people who have implemented these with success that may have some tips. Thanks.
What is the call path (PSTN connectivity, Type of Voice Gateway, etc) See example below
PSTN -- PRI/POTS/SIP -- Voice Gateway -- MGCP/H323/SIP -- CUCM -- ATA 190 -- Fax Machine
Also, I do not see an attachment in the previous post.
I think I may have figured it out. Our path goes PRI->Voice Gateway->h323->CUCM->ATA-> Fax
With the help of the former IT guy, I was looking in the configuration of the switch port that the ATA is connected to and I noticed that the port was not on our voice VLAN (it was on our regular data VLAN) and did not have the auto qos settings we normally apply to ports that are home to our Cisco phones. I put the port on our voice VLAN, applied qos for voip and rebooted the ATA. I made sure the ATA had registered in CUCM and it did have a correct ip issued to our voice vlan. I tested a fax from a problematic party and it came through on the first try. I don't want to claim victory just yet. I am just wondering why it worked at all when the ATA didn't have qos settings applied? I would have thought it wouldn't have worked at all.
Well scratch that. I ran another test and observed the fax machine picking up a call, communicating for a brief moment and then the transmission stops. I wait a minute or so and the sending fax makes another attempt. I can't make heads or tails of the attached debug log but what I am showing here is the repeated attempts.
debug-info-for-ata-190.txt
I MIGHT be onto something but I am still testing. I logged into our Cisco voice gateway and saw that voip was configured for:
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
When I logged into CUCM I saw that the default setting for fax mode for an ATA 190 was T.38 Fax Relay. I changed that to NSE Fax pass-through—g711ulaw. All test faxes from the outside to us made it through. I am still waiting for a bigger sample size before declaring victory.
What I don't get is, if there was a misconfiguration I would think it wouldn't work at all?
Misconfiguration is not the term
VoIP service provider <=> cucm pbx <=> ata190
The connection from at a to cucm is negotiated, the VoIP provider to pbx is negotiated, if there are difference the process includes transition/translation, potentially interruption, delay cause a drop.
Besides fax machine you could have fax to email, .....ifax.
Check the cucm manual which fax is preferred, the one on the ATA might be .....
