RECO_IS
How to load Exchange 2013 Management Shell into regular PowerShell using a function?
I can't seem to figure out how to launch Exchange Management Shell using a function in regular PowerShell window.
If I run the following command in regular powershell, everything works:
However,
When I create a function with the same command, running the function does not load Exchange commands:
I suspect that this is a scoping issue but I can't figure out how to get this function to load exchange shell.
Any help would be greatly appreciated.
Thanks.
. 'C:\Program Files\Microsoft\Exchange Server\V15\bin\RemoteExchange.ps1'; Connect-ExchangeServer -auto -ClientApplication:ManagementShell
However,
Function Connect-Exchange {
Write-Host Loading Exchange...
Thanks.
Oh gotcha. You may have to get assistance from another expert on that.
Have you reviewed these references? It's the only supported method I know to connect to Exchange using remote PowerShell.
You will need to do something more like this...
- https://technet.microsoft.com/en-us/library/dd335083(v=exchg.160).aspx
- https://www.codetwo.com/kb/how-to-connect-to-exchange-server-via-powershell/
$UserCredential = Get-Credential
$SessionOpt = New-PSSessionOption -SkipCACheck:$true -SkipCNCheck:$true -SkipRevocationCheck:$true
$Session = New-PSSession -ConfigurationName Microsoft.Exchange -ConnectionUri http://ExchangeFQDN/powershell/ -Credential $UserCredential -SessionOption $SessionOpt
Import-PSSession $Session
Hi Todd,
This does work but it takes too long to connect this way.
In general how can I run a command using a function but as if it was typed directly into the console?
I ended up declaring the function as part of a profile and not part of a Module. It was the only way to get everything working correctly.
Thanks for your help.
Provided sufficient solution to user question. Closing question and assigning points.
My question is how do I make it run by using a function. Because I can run it by typing it in to the console, but if I wrap it in a function it does not.
Thanks.
