IP4IT Staff
Which provides the best quality radio over Denon AVR X4300 surround sound system; Internet radio or external FM Antenna?
We have a Denon AVR X4300 which is connected with speakers and we have surround sound for music, radio, etc.
https://www.denon.co.uk/uk/product/homecinema/avreceiver/avrx4300hv2
Back of Denon:
https://www.google.ie/search?dcr=0&biw=1125&bih=663&tbm=isch&sa=1&ei=i-2oWtG2K8iHgQaApqjYAg&q=denon+avr+x4300&oq=denon+avr+x4300&gs_l=psy-ab.3..0l2j0i24k1l8.629949.634464.0.634927.23.15.0.0.0.0.471.1897.2-1j2j2.5.0....0...1c.1.64.psy-ab..18.5.1896...0i67k1.0.WNcM6UitMAU#imgrc=JSOEvsQMsE7U3M:
We are having problems connecting FM internet radio stations to our Denon AVR X4300.
At most, 3 radio stations connect with use of internal FM radio antenna connected to Denon AVR X4300.
A different radio in the room, which is a basic radio with antenna, has over 10 radio stations it can connect to.
1. Which provides the best quality radio over the surround sound system; Internet radio or external FM Antenna?
2. If external FM Antenna is best quality for radio, what would be the best external/ outdoor FM DAB radio antenna to use for Denon AVR X4300?
3. No point in buying and installing an external antenna and then finding out the the sound quality is better on one of the internet services.
It would be redundant and annoying to finding that out later.
Robbie
Back of Denon:
Robbie
All your help is greatly appreciated.
Assuming we have great internet connection, great FM signal and a great HiFi setup, what would you recommended would provide better sound quality for radio: Internet radio or FM radio via external/outdoor aerial?
Robbie
