public Button clickedButton1 = null;
public Button clickedButton2 = null;
public Button clickedButton3 = null;
public Button clickedButton4 = null;
public DateTime clickTime1 = new DateTime(2011,1,1,1,1,1,1);
public DateTime clickTime2 = new DateTime(2011, 1, 1, 1, 1, 1, 1);
public DateTime clickTime3 = new DateTime(2011, 1, 1, 1, 1, 1, 1);
public DateTime clickTime4 = new DateTime(2011, 1, 1, 1, 1, 1, 1);
TimeSpan timeDiff1;
TimeSpan timeDiff2;
TimeSpan timeDiff3;
TimeSpan timeDiff1Now;
TimeSpan timeDiff2Now;
public string LetterToDisplay = "";
public int cmdAbcPressed = 0;
public int cmdDefPressed = 0;
private void ProcessButton(object sender, EventArgs e)
clickedButton4 = clickedButton3;
clickTime4 = clickTime3;
clickedButton3 = clickedButton2;
clickTime3 = clickTime2;
clickedButton2 = clickedButton1;
clickTime2 = clickTime1;
clickedButton1 = sender as Button;
clickTime1 = DateTime.Now;
timeDiff1 = clickTime1-clickTime2;
timeDiff2 = clickTime2 - clickTime3;
timeDiff3 = clickTime3 - clickTime4;
timeDiff1Now = DateTime.Now-clickTime2;
timeDiff2Now = DateTime.Now - clickTime3;
//MessageBox.Show(clickedButton1.Name + " clicked at " + clickTime1);
private void cmdAbc_Click(object sender, EventArgs e)
//string LetterToDisplay = "";
cmdAbcPressed += 1;
cmdDefPressed = 0;
//if (LetterToDisplay!="")
// DisplayText(LetterToDisplay);
ProcessButton(sender,e);
if (clickedButton2 == null)
LetterToDisplay = "a";
else if(clickedButton2 != clickedButton1)
else if (timeDiff1.TotalMilliseconds > 500)
//else if (((clickTime1 - clickTime2).Milliseconds > 500))
else
if (clickedButton3 == null)
LetterToDisplay = "b";
else if (clickedButton3 != clickedButton2)
else if (timeDiff2.TotalMilliseconds > 500)
//else if (((clickTime2 - clickTime3).Milliseconds > 500))
else
LetterToDisplay = "c";
txtDebug.Text = txtDebug.Text + (timeDiff1.TotalMilliseconds + " | " + timeDiff2.TotalMilliseconds + " | " + clickTime1 + " | " + clickTime2 + " | " + clickTime3 + " | " + clickTime4 + (char)13 + (char)10);
if (clickedButton3 != null)
if ((timeDiff2Now).TotalMilliseconds > 500)
clickTime1 = new DateTime(2011, 1, 1, 1, 1, 1, 1);
if (clickedButton2 != null)
if ((timeDiff1Now).TotalMilliseconds > 500)
if (clickedButton1 != null)
if ((DateTime.Now - clickTime1).TotalMilliseconds > 500)
using System;
using System.Text.RegularExpressions;
using System.Windows.Forms;
using System.IO;
namespace
public partial class Form1 : Form
public DateTime FirstClickTime = new DateTime(2011, 1, 1, 1, 1, 1, 1);
public DateTime SecondClickTime = new DateTime(2011, 1, 1, 1, 1, 1, 1);
public DateTime ThirdClickTime = new DateTime(2011, 1, 1, 1, 1, 1, 1);
public DateTime FourthClickTime = new DateTime(2011, 1, 1, 1, 1, 1, 1);
TimeSpan timeDiff1;
TimeSpan timeDiff2;
TimeSpan timeDiff3;
public string FirstKey = "";
public string SecondKey = "";
public string ThirdKey = "";
public string FourthKey = "";
public DateTime StartTime;
public DateTime EndTime;
public int Keystrokes = 0;
public int TimeTaken = 0;
public Form1()
InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
StartTime = DateTime.Now;
using (StreamWriter sw = new StreamWriter(@"D:\OneDrive\Documents\Tests\OldMobileKeyboard\MobKeyboard4\Results.txt", false))
sw.WriteLine("Started at " + StartTime);
private void textBox1_KeyUp(object sender, KeyEventArgs e)
textBox1.Text = Regex.Replace(textBox1.Text, @"[\d-]", "");
textBox1.Text = textBox1.Text.Replace("?", "");
private string ReturnKeys(string KeyPressed)
string OutputKey = "";
switch (KeyPressed)
case "2":
OutputKey = "abc";
break;
case "3":
OutputKey = "def";
break;
case "4":
OutputKey = "ghi";
break;
case "5":
OutputKey = "jkl";
break;
case "6":
OutputKey = "mno";
break;
case "7":
OutputKey = "pqrs";
break;
case "8":
OutputKey = "tuv";
break;
case "9":
OutputKey = "wxyz";
break;
case "0":
OutputKey = " ";
break;
case "#":
OutputKey = "#";
break;
case "*":
OutputKey = "*";
break;
default:
OutputKey = "???";
MessageBox.Show("Please enter one of the following keys: 234567890*#");
break;
return OutputKey;
private void textBox1_KeyPress(object sender, KeyPressEventArgs e)
try
using (StreamWriter sw = new StreamWriter(@"D:\OneDrive\Documents\Tests\OldMobileKeyboard\MobKeyboard4\Results.txt", true))
Keystrokes += 1;
FourthKey = ThirdKey;
FourthClickTime = ThirdClickTime;
ThirdKey = SecondKey;
ThirdClickTime = SecondClickTime;
SecondKey = FirstKey;
SecondClickTime = FirstClickTime;
FirstKey = e.KeyChar.ToString();
FirstClickTime = DateTime.Now;
timeDiff1Now = DateTime.Now - FirstClickTime;
timeDiff1 = FirstClickTime - SecondClickTime;
timeDiff2 = SecondClickTime - ThirdClickTime;
timeDiff3 = ThirdClickTime - FourthClickTime;
int NumberOfClicks = 0;
switch (FirstKey)
case ("2"):
case ("3"):
case ("4"):
case ("5"):
case ("6"):
case ("7"):
case ("8"):
case ("9"):
case ("0"):
case ("*"):
case ("#"):
break;
default:
e.Handled = true;
break;
if (FirstKey != SecondKey)
LetterToDisplay = ReturnKeys(FirstKey).Substring(0, 1);
NumberOfClicks = 1;
TimeTaken += 500;
else if (FirstKey == SecondKey && timeDiff1.TotalMilliseconds >= 500)
NumberOfClicks = 1;
TimeTaken += 500;
else if (SecondKey == ThirdKey && timeDiff2.TotalMilliseconds < 500 && ThirdKey == FourthKey && timeDiff3.TotalMilliseconds >= 500)
LetterToDisplay = ReturnKeys(SecondKey).Substring(2, 1);
NumberOfClicks = 3;
TimeTaken += 500;
else if (SecondKey == ThirdKey && timeDiff2.TotalMilliseconds < 500 && ThirdKey == FourthKey && timeDiff3.TotalMilliseconds < 500)
LetterToDisplay = ReturnKeys(SecondKey).Substring(3, 1);
NumberOfClicks = 4;
TimeTaken += 100;
else if (FirstKey == SecondKey && timeDiff1.TotalMilliseconds < 500 && SecondKey != ThirdKey)
LetterToDisplay = ReturnKeys(FirstKey).Substring(1, 1);
NumberOfClicks = 2;
TimeTaken += 100;
else if (FirstKey == SecondKey && timeDiff1.TotalMilliseconds < 500 && SecondKey == ThirdKey && timeDiff2.TotalMilliseconds >= 500)
NumberOfClicks =2;
TimeTaken += 100;
else if (FirstKey == SecondKey && timeDiff1.TotalMilliseconds < 500 && SecondKey == ThirdKey && timeDiff2.TotalMilliseconds < 500)
LetterToDisplay = ReturnKeys(FirstKey).Substring(2, 1);
NumberOfClicks = 3;
TimeTaken += 100;
else
NumberOfClicks = 1;
TimeTaken += 500;
if (NumberOfClicks >1)
textBox1.Text = textBox1.Text.Remove(textBox1.Text.Length - 1, 1);
textBox1.Text = textBox1.Text + LetterToDisplay;
sw.WriteLine(e.KeyChar);
textBox1.Text= Regex.Replace(textBox1.Text, @"[\d-]", "");
catch (Exception ex)
MessageBox.Show(ex.Message.ToString());
private void button1_Click(object sender, EventArgs e)
EndTime = DateTime.Now;
sw.WriteLine("Ended at " + EndTime);
sw.WriteLine("Duration" + (EndTime - StartTime));
sw.WriteLine("Minimum Duration " + TimeTaken +" milliseconds");
sw.WriteLine("keystrokes " + (Keystrokes));
sw.WriteLine("To make this more configurable I would put each key in a cross reference file with the chracters assigned to it.");
Environment.Exit(0);
As it_saige suggested above, you can hook into the windows messaging system and create your own handler to simulate a double-click event using timing other than what the operating system uses.
