Hi Experts ,
I did export and import for a virtual a mchine from one host to another and it worked fine and the restored machine working propely ..
my Questions :
1- i faced IP address issue with the new one so re assigned the IP manually through the OS .. is there anothery way to solve this issue from the begining or this is how it should go?
2- I want to do another Export for this restored system after some modfication on application level but iwant to imorte it to the same host .. will that make any problemfor me? i am just renaming the virtual machine name from inventory so the internal folders as it is.. howerver if no issue to keep both systems on same host i want to keep it simple process
3-my Application vendor is asking for shared (RDM) LUN between the 2 virtual machines for os cluster purpose ,, can you advise step by step how to do the RDM?
2. There should be no, issues other than changing the inventory name, and making sure the MAC Addresses and IP Addresses are unique.
3. Do you have shared storage you can use, to create the RDM from your iSCSI or FC SAN ?
