Object reference not set to an instance of an object.  MemoryCache.Default.Get(guidToken) as ResponseObject;
yguyon28
yguyon28 used Ask the Experts™
on
I'm getting the following error on my objResponse set to null:
Object reference not set to an instance of an object.... This
var searchCriteria = objResponse.Model as InvoicePrintingParameters;  My objresponse is set to null
       private void AddEmailedCustomersToCacheObject(string guidToken, List<int> emailedCustomers)
            var objResponse = MemoryCache.Default.Get(guidToken) as ResponseObject;
            searchCriteria.listEmailedCustomers = emailedCustomers;
            ResponseObject result = new ResponseObject() { Success = objResponse.Success, Message = objResponse.Message, Model = searchCriteria };
            MemoryCache.Default.Remove(guidToken);
            MemoryCache.Default.Add(guidToken, result, DateTime.Now.AddMinutes(1));
Watch Question
Do more with
Expert Office
Chinmay PatelChief Technology Ninja
Distinguished Expert 2018
As per the design of the ObjectCache, if the item with a given key is not found it will return null. Are you sure that item exists in the cache?
I think what I'm trying to do is if the memory cache is null is to write a better logic than what I have created.
Something like this? because if
for some reason then can not proceed further.
if(objResponse == null )
// handle the issue
// you might return; from here or do something else, maybe log the exception - if that is the case.
}else
Do more with
Expert Office
Start 7-Day Free Trial
