J Z
10 Gb connection for blade-servers in a C3000 chassis
Question on HP C3000 server-chassis:
- Just to be clear: I know only a C7000 has automatic failover for the interconnect modules in the back.
- But I have a C3000 chassis (partnr 437504-B21) currently 1 Gb connected with 3 HP ProLiant BL460c Gen8 v1 blade-servers (partnr 655492-004) in it. They used to be sitting in a C7000 chassis with a 10 Gbps FlexFabric module in the back. So they have the onboard 10 Gbps FlexLOM (if I remember the terminology correctly).
The question is: I want to repurpose these servers and the chassis. Is there a way I can connect them in this C3000 chassis over 10 Gbps with a backup/failover at the hypervisor level to a 1 Gbps connection? I just want to be sure whether that is possible and what I need in terms of mezzanine cards etc.
