Avatar of Howard Bash
Howard Bash
SharePoint 2016 Missing Filter Web Parts
Have looked in site settings and cannot find the setting which enables the filters.
Microsoft SharePoint* web part
Piotr Strycharz
Piotr Strycharz
Filter Web Parts are the part of the 'SharePoint Server Enterprise Site Collection features' feature, which in turn activates "BizApps Site Templates" feature that contains web parts.
Howard Bash
It appears (how to tell) that this install is SharePoint Server Standard  as there is a "SharePoint Server Standard Site Collection Features".  If it is Standard am I out of look on these web parts?
Piotr Strycharz
I do not know what is actually included in the standard version of SharePoint. Check if you have C:\Program Files\Common Files\microsoft shared\Web Server Extensions\15\TEMPLATE\FEATURES\BizAppsSiteTemplates folder on the disk. If so -  you are free to install this feature. Please note that some webparts may not work with your SP version. Again - not sure as I do not have access to Standard Version.
fblack61
Howard Bash
I found some web parts in this folder:
C:\Program Files\Common Files\microsoft shared\Web Server Extensions\16\TEMPLATE\FEATURES\BizAppsSiteTemplates\dwp.  I assumpe the "16" in the path is because it's SP1016.
Here are the files I see:
AuthoredListFilter
BusinessDataFilter
DateFilter
FilterActions
OlapFilter
PageContentFilter
QueryStringFilter
SplistFilter
TextFilter
UserContextFilter
However,  I don't see a Filters category when I go to add a web part to  a page.
Piotr Strycharz
Did you run the command?:
Enable-SPFeature BizAppsSiteTemplates -URL http://YOUR-SITE-URL
I did check it for empty site (STS#1) and it works. In fact, I have some more webparts: AuthoredListFilter.webpart
BusinessDataActionsWebPart.dwp, BusinessDataAssociationWebPart.webpart, BusinessDataDetailsWebPart.webpart, BusinessDataFilter.dwp, BusinessDataItemBuilder.dwp, BusinessDataListWebPart.webpart, DateFilter.dwp, FilterActions.dwp, IndicatorWebPart.dwp, IViewWebPart.dwp, KpiListWebPart.dwp, OlapFilter.dwp, PageContextFilter.webpart, ProjectSummary.webpart, QueryStringFilter.webpart, SpListFilter.dwp, TextFilter.dwp, UserContextFilter.webpart, WSRPConsumerWebPart.dwp. But you have at least DateFilter, and it it enought to be visible in Filters section.
Howard Bash
So, I ran that command and it failed for me.  Here is the error:
Error Message
Piotr Strycharz
Howard Bash
Command failed for me.  "The feature is not a farm level feature and is not found in a Site Level defined by http://some-site/.
Piotr Strycharz
Again, you did not install feature. If the feature is not installed the error is "Feature is not a Farm Level Feature...", if it does not exist the error is "Failed to find XML...".
PS C:\> Enable-SPFeature NonInstalledFeature -Url http://test
Enable-SPFeature : The Feature is not a Farm Level Feature and is not found in a Site level defined by the Url http://playdocs.
At line:1 char:1
+ Enable-SPFeature NonInstalledFeature -Url http://test
    + CategoryInfo          : InvalidData: (Microsoft.Share...etEnableFeature:SPCmdletEnableFeature) [Enable-SPFeature], SPCmdletException
    + FullyQualifiedErrorId : Microsoft.SharePoint.PowerShell.SPCmdletEnableFeature
PS C:\> Install-SPFeature NonExistingFeature
Install-SPFeature : Failed to find the XML file at location '15\Template\Features\NonExistingFeature\feature.xml'
At line:1 char:1
+ Install-SPFeature NonExistingFeature
    + CategoryInfo          : InvalidData: (Microsoft.Share...tInstallFeature:SPCmdletInstallFeature) [Install-SPFeature], SPException
    + FullyQualifiedErrorId : Microsoft.SharePoint.PowerShell.SPCmdletInstallFeature
Install the feature first:
Install-SPFeature BizAppsSiteTemplates
