Avatar of Jo Cox
Jo CoxFlag for United Kingdom of Great Britain and Northern Ireland
Power shell events and SQL
Hi Experts
Can I use powershell to set an event, in this case monitor a directory for a file to be created then spawn some SQL that will take the contents of the file as a parameter?
Jo
PowershellWindows 10AzureWindows Server 2016SQL
Jo Cox
Avatar of oBdA
oBdA
Avatar of Jo Cox
Jo Cox
This looks really useful, thank you.
What do you think would be the best way to approach registering something like this as a service.
Avatar of oBdA
oBdA
Either as a scheduled task, with a trigger of System Startup, or this:
NSSM - the Non-Sucking Service Manager
https://nssm.cc/
Avatar of Jo Cox
Jo Cox
Many Thanks, gives me a good starting place to work from.
SQL
SQL
SQL (Structured Query Language) is designed to be used in conjunction with relational database products as of a means of working with sets of data. SQL consists of data definition, data manipulation, and procedural elements. Its scope includes data insert, query, update and delete, schema creation and modification, and data access control.
61K
