How to extract DataGridView another with sum-up cell values for same values for same column values in vb.net
I have a DataGridView output like below;
As you can some values are same with the red-boxed columns and they values on the right side.
I want to sum-up that values like below;
What's the logic way to create a datagridview with like this structure which has source from another datagridview.
HakanAsked:
Éric MoreauSenior .Net ConsultantCommented:
I would use LINQ to sum up the values. The DataGrid itself can't do it. Have a look at https://stackoverflow.com/questions/13998258/datatable-group-by-with-linq-in-vb-net
HakanAuthor Commented:
Hi Mr. Moreau
Could you please help me how can i convert cell values to double?
I have no binding source in my datagridview first i turn it to datatable like in below link;
https://stackoverflow.com/questions/3109009/how-to-make-a-datatable-from-datagridview-without-any-datasource
After that i used your reference but the problem is i need to convert these cell values from string to double.
How can i do that ?
Thanks.
you can try something like this:
dim str as string = "1e-06;
dim d as double = double.Parse(str)
Console.WriteLine(str)
Exploring ASP.NET Core: Fundamentals
Learn to build web apps and services, IoT apps, and mobile backends by covering the fundamentals of ASP.NET Core and  exploring the core foundations for app libraries.
I tried below and it gives me "Input string was not in a correct format."
  dRow(cell.ColumnIndex) = Double.Parse(cell.Value)
 Dim dgv As DataGridView = GUI.dgvCheckBodyComputed
            Dim dt As DataTable = New DataTable()
            For Each col As DataGridViewColumn In dgv.Columns
                dt.Columns.Add(col.HeaderText)
            Next
            For Each row As DataGridViewRow In dgv.Rows
                Dim dRow As DataRow = dt.NewRow
                For Each cell As DataGridViewCell In row.Cells
                Next
                dt.Rows.Add(dRow)
            Next
on which value? because it should work! Hope you are not trying to do it on your Parent column!
I just checked and noticed i already add data to other columns like Mass, Cog-x, Cog-y, Cog-z in type of Double.
But it gives error for  .mass = MonthGroup.Sum(Function(r) r.Field(Of Double)("Mass")) as System.InvalidCastException: 'Specified cast is not valid.'
        Public Shared Sub TestMethod()
            Next
                    dRow(cell.ColumnIndex) = cell.Value
                Next
                dt.Rows.Add(dRow)
            Next
            Dim query = From row In dt
                        Group row By Parent = row.Field(Of String)("Parent") Into MonthGroup = Group
                        Select New With {
                            Key Parent,
                            .mass = MonthGroup.Sum(Function(r) r.Field(Of Double)("Mass")),
                            .cogx = MonthGroup.Sum(Function(r) r.Field(Of Double)("CoG-x")),
                            .cogy = MonthGroup.Sum(Function(r) r.Field(Of Double)("CoG-y")),
                            .cogz = MonthGroup.Sum(Function(r) r.Field(Of Double)("CoG-z"))
            For Each x In query
                GUI.DataGridView1.Rows.Add(x.mass, x.cogx, x.cogy, x.cogz)
            Next
        End Sub
it works for me! You probably have incorrect values. Try with a smaller number of rows.
Public Class Form1
    Private mds As DataSet
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        CreateData()
        DataGridView1.DataSource = mds.Tables(0)
        Dim query = From row In mds.Tables(0)
                Select New With {
                Key Parent,
        DataGridView2.DataSource = query.ToList()
    End Sub
    Private sub CreateData()
        Dim dt As New DataTable("Test")
        With dt
            .Columns.Add("Parent", GetType(String))
            .Columns.Add("Mass", GetType(Double))
            .Columns.Add("CoG-x", GetType(Double))
            'Add rows
            .LoadDataRow(New Object() {"Model", 1E-06,0}, True)
            .LoadDataRow(New Object() {"Model", 1E-06,-0.5499}, True)
            .LoadDataRow(New Object() {"Model", 1E-06,-0.5719}, True)
            .LoadDataRow(New Object() {"@S_bush...", 5E-07,0.5561}, True)
            .LoadDataRow(New Object() {"@S_bush...", 5E-07,-0.839775}, True)
            .LoadDataRow(New Object() {"@S_fawheelend...", 35.61,-9.629649721}, True)
            .LoadDataRow(New Object() {"@S_fawheelend...", 55.3,-9.629649721}, True)
        End With
        mds = new DataSet()
        mds.Tables.Add(dt)
    End sub
End Class
Thank you Mr. Moreau. You're right!. It's now corrected.
Visual Basic.NET
