Start Free TrialLog in
Avatar of Massimo Scola
Massimo ScolaFlag for Switzerland
jQuery and Spring MVC: Problems when using Ajax POST
I have written my first Spring MVC controller. While I have no problems with GET requests, I am still having some issues with POST methods.
This is the code in my controller:
@RequestMapping(value = "/editorsWriters", method = RequestMethod.POST)
    public <HttpServletRequest> ResponseEntity<List<FreelancerContactWriterListView>> getEditorsWriters(
        @RequestParam int[] languageIds,
        @RequestParam int[] summaryGroupIds,
        @RequestParam String[] writerStates,
        HttpServletRequest request, HttpServletResponse response) {
        WriterState[] writerState = Arrays.copyOf(writerStates, writerStates.length, WriterState[].class);
        List<FreelancerContactWriterListView> writers = writerService.getActiveWriters(languageIds, summaryGroupIds, writerState)
        .stream()
        .map(writer -> this.convertTo(writer))
        .collect(Collectors.toList());
           return new ResponseEntity<List<FreelancerContactWriterListView>>(writers, HttpStatus.OK);
and this is the JavaScript code:
 $("#search").on("click", function(e) {
            var languages=$("#languages").val();
            var summaryGroups = $("#summaryGroups").val();
            var writerStates = $("#writerState").val();
            var myObject = new Object();
            myObject.languageIds = languages;
            myObject.summaryGroupIds = summaryGroups;
            myObject.writerStates = writerStates;
            var myData = JSON.stringify(myObject);
            console.log(myData);
            $.ajax({
                method: 'POST',
                dataType: 'json',
                data: myData,
                url:'/api/pps/contactFreelancers/editorsWriters',
                contentType: "application/json"
This is the JSON sent:
{"languageIds":["1"],"summaryGroupIds":["11"],"writerStates":["PROBATION","REGULAR"]}
The problem is that I get a POST 404 (Not Found) error in the JavaScript console
POST https://dev1.getabstract.com/api/pps/contactFreelancers/editorsWriters 404 (Not Found)
and the following message in the terminal of my IDE:
2019-07-14 22:49:06,923 DEBUG [BaseControllerExceptionHandler] Page not found for the URL https://dev1.getabstract.com/api/pps/contactFreelancers/editorsWriters with query null: Required int[] parameter 'languageIds' is not present
So it is reaching or sending the POST to the correct URL, but what am I doing wrong?
Is the way I have created the data wrong?
languages, summaryGroups and writersStates are all arrays and I am putting them together into one JSON.
Thanks for your help
Massimo
Avatar of mccarl
mccarl
Flag of Australia image
for testing, try to replace :
by :
myObject.languageIds = [1];
and another test, replace :
by :
var myData = myObject;
The problem was a type issue: string/integer
I solved this problem by putting the validation into a bean.
Thanks a lot!
