Problem after changing Inherits System.Web.UI.Page to Inherit BasePage (that includes Inherit System.Web.UI.Page)
ullenulle
ullenulle used Ask the Experts™
on
Hi there.
I'm a step further in my VB.NET study... and I ran into a problem when I'm supposed to create a BasePage.vb where I add the "Inherit System.Web.UI.Page" and after that edit an existing code behind from "Inherit System.Web.UI.Page" to "Inherit BasePage".
When I test the page, I get an error, that:
.... is not allowed here because it does not extend class 'System.Web.UI.Page'.
Even though it's all a bit new to me, it doesn't make sense, because the BasePage does inherit the System.Web.UI.Page...
Any idea what I'm doing wrong?
Let me know if you need more info.
Best regards
Ulrich
Watch Question
Do more with
Expert Office
Chinmay PatelChief Technology Ninja
Distinguished Expert 2018
Hi Ulrich,
Couple of questions
1. What you are trying to do?
2. Please share the code that is giving you this error.
3. Which version of Visual Studio you are using?
Regards,
Chinmay.
Hi.
Thank you for your response. Here's some answers to your questions:
1) and 2): I have this simple beginning of a project with a login.aspx page looking like this:
<%@ Page Title="Login to DAMMED" Language="vb" AutoEventWireup="false" MasterPageFile="~/MasterPages/Frontend.Master" CodeBehind="Login.aspx.vb" Inherits="dammed.Login" %>
<asp:Content ID="Content1" ContentPlaceHolderID="head" runat="server">
</asp:Content>
<asp:Content ID="Content2" ContentPlaceHolderID="cpMainContent" runat="server">
</asp:Content>
The code behind looks like this:
Partial Class Login
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
    End Sub
End Class
Then I created a BasePage like this:
Public Class BasePage
    Private Sub Page_PreRender(
        ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.PreRender
        If Me.Title = "Untitled Page" Or String.IsNullOrEmpty(Me.Title) Then
            Throw New Exception(
                "Page title cannot be ""Untitled Page"" or an empty string.")
        End If
    End Sub
End Class
That BasePage is supposed to be inherited in the login.asps.vb, so it will look like this:
Partial Class Login
    Inherits BasePage
    End Sub
End Class
Right afterdoing this, there's a red curl under "Load" indicating an error.
If I ignore and test the page, I first get a warning that there were errors building the project. I contunied anyways, and I get this error:
Login.aspx.vb(4,93): error BC30590: Event 'Load' cannot be found.
3) I use Visual Studio 2019 (version 16.1.6)
Best regards
Ulrich
Hi Ulrich,
Must be something else. I could run everything fine (Even though VS was showing many errors).
Finally I changed file names and voila...  Sample this
PageRoot.vb
Public Class PageRoot
            Console.WriteLine("Page title cannot be ""Untitled Page"" or an empty string.")
        End If
    End Sub
End Class
TestForm.aspx
<%@ Page Language="vb" AutoEventWireup="false" CodeBehind="TestForm.aspx.vb" Inherits="CrmXpress.VB.WebFormApp.TestForm" %>
<!DOCTYPE html>
<head runat="server">
    <title>TEST</title>
</head>
<body>
        <div>
            Ha Ha Ha...
        </div>
    </form>
</body>
</html>
TestForm.aspx.vb
Public Class TestForm
    Inherits PageRoot
    End Sub
End Class
Regards,
Chinmay.
Hi Chinmay.
Hmm... I guess I just need to start over again. I must've written a name wrong somewhere. Thank you for your response. :-)
Best regards
Ulrich
Hi Ulrich,
Glad I could help. I just changed the name of the files. I suspect they were conflicting with some system reserved keywords. You don't really need to start over.
Regards,
Chinmay.
Do more with
Expert Office
Start 7-Day Free Trial
