Hardware
HP Officejet Pro X476dw MFP - Error: "There is a problem with the printer or ink system. Turn printer off, then on. If problem persists, contact HP"
We installed a HP Officejet Pro X476dw MFP for someone a bit over a year ago.
When we set it up and tested it, all worked as expected.
We have heard that this printer has not been working the last few weeks so I went to check this out for them.
When I went to power the printer on, it started up but an error message appeared on the touch screen: "There is a problem with the printer or ink system. Turn printer off, then on. If problem persists, contact HP".
There is no way of by passing this error and after trying power button, it says it is initializing something and not to turn off printer but no loading for initialising.
Inside the printer are 3 setup ink cartridges (coloured ones that came with printer) and 1 non-setup ink cartridge (black).
I tried the following to try and fix the printer:
1. Pressed and held power button to turn printer off - Printer did not power off.
2. Replaced non-setup ink cartridge (black) with setup ink cartridge (black) - Started initialising for 2 seconds then same error message as before
3. Took out all ink cartridges from printer then tried each one at a time - Started initialising for 2 seconds then same error message as before
4. Reset printer by plugging out power cord for 60 seconds then plugging back in printer and powering on - Powered on but same error message as before
5. Opened paper tray and closed while printer on - Noise was made by printer for few seconds then quiet
How do we fix this issue?
Robbie
Robbie
imo just buy a new printer....repairing cosyt more than a new one
Hardware
Hardware includes cell phones and other digital living devices, tablets, computers, servers, peripherals and components, printers and scanners, gaming consoles, networking hardware such as routers, hubs, switches and modems, storage devices and security equipment such as firewalls and other appliances.
