Dan
port channel speed problem between cisco switch and synology NAS
I have cisco switch, a 3850 and created a port channel for 3 ports. Each port is a 10G port. On the other side, I'm using a synology with 4 (1G) ports. I did a LACP on that side as well and bonded 3 of the ports. It shows the link at 3000 Mbps.
On the cisco switch, the port channel shows a speed of a-1000
Not sure why it's only connecting at 1000, but when I did a speed ?, it only gives me the options of 10, 100,1000, auto and nonegotiate. I tried auto and it puts it back to a-1000. I tried nonegotiate and it didn't take that command. So how do I get the port channel to run at 10G, so it can at least transfer at 3G?
