Skale
How to access a project methods from another project in same solution in C#
I have a two projects Project1 and Project 2 in same solution.
I'd like to use some functions from Project2 but i couldn't do it without defining a static field.
Is it normal? or How can i achieve this. Any help would be great to define it properly.
PS: I added Project2 to Project1's reference.
Project1's sample class:
This is Project2's sample class:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace Project1
public class HelloFromProject1
public void SayHello()
// Calling method from another project here
Project2.HelloFromProject2.SayHello();
using System;
using System.Linq;
using System.Text;
namespace Project2
public class HelloFromProject2
Console.WriteLine("Hello From Project 2");
Hi Chinmay,
It's like on example i'm using public keyword on classes
Sorry I didn't catch that.
As such now all you need is to instantiate class (Not Static classes must be instantiated)...
If you don't need to keep the pj2 for further usage then
Regards,
Chinmay.
HelloFromProject2 pj2 = new HelloFromProject2();
pj2.SayHello();
new HelloFromProject2().SayHello()
Regards,
Chinmay.
Thanks :) Also you mentioned you dont want to use static why? What's the disadvantages?
Is it normal?
Just in case you haven't noticed. The code is identical to that you would use for another class inside the same project (using the namespace within the same project is implied - you could specify it if you wished).
Is it normal?
Just make sure the class you are trying to access is marked Public (Static will do, but I don't recommend it unless there is a solid reason to use Static).
Regards,
Chinmay.
