Avatar of trevor1940
trevor1940
perl: Spliting strings into parts with REGEX
Given the code snippet bellow  I need to extract each Place Name & Coord string
There might be zero 1 or many however I can't be sure what the delimiter will be when there are multiple the two samples are either  a comer or semi colon
I do know
 Place Name (Coord string) are in this format
print "Hello World!\n";
my @examples=("Place Name (Coord string )","Place Name2 (Coord string 2);Place Name3 (Coord string 3);Place Name4 (Coord string 4)","Place Name5 (Coord string 5), Place Name5 (Coord string 5),Place Name6 (Coord string 6)","Not Wanted");
foreach my $example (@examples){
    if($example =~ m/(.*)\((.*)\)([,;])?/g){
        my $Place =$1;
        my $Coord = $2;
        # do stuff with each
        print "$Place  $Coord\n";
I thought about splitting on the delimiter then pushing into an array which might work for multiple but seems to fail for single
Regular ExpressionsPerl
trevor1940
Terry Woods
What if you use this as a pattern?
That would match groups of characters excluding the delimiter.
Dave Cross
noci
trevor1940
Thanx
Both Solutions work
James Murphy
