marrowyung
find missing unused index and missing index using Brent first response kit
hi,
as continue from https://www.experts-exchange.com/questions/28994215/how-to-install-upgrade-the-Blitz-responder-kit.html
https://www.experts-exchange.com/questions/28711297/find-missing-index-or-wanted-MS-SQL-index-from-reading-execution-plan.html
https://www.experts-exchange.com/questions/28684331/Finding-missing-indexes-adding-them-to-SQL.html
how to make use of brent first response kit to generate create index statement for missing index and drop index statement for unused index?
please shows example.
What about one that is only used during year-end processing that makes a 15 hour process run in 1 hour? If you remove that index because it is only used once a year, you can greatly impact performance next time that job runs.
yeah you are right! I will let developer to verify it before it drop, as simple as this!
DBA here usually do not know this logic as developer will not tell DBA.
so brent first response kit to generate the index for add and drop and let developer review it should be the fastest way ?
No comment has been added to this question in more than 21 days, so it is now classified as abandoned.
I have recommended this question be closed as follows:
Split:
-- 'Máté Farkas' (https:#a43183557)
-- 'slightwv (䄆 Netminder)' (https:#a43183677)
If you feel this question should be closed differently, post an objection and the moderators will review all objections and close it as they feel fit. If no one objects, this question will be closed automatically the way described above.
seth2740
Experts-Exchange Cleanup Volunteer
Split:
seth2740
no , let the tools kit find out first and we review.
we can check it query by query.
btw, what is your best way to find missing index and add it accordingly ? and how about unused index (it hurts Write operation, so we must be able to do it.
