troubleshooting Question
Dell XPS 13 P54G002 laptop replacement battery gives "Battery not recognised" error after several hours of use.
Avatar of Manager Cool Aroma Spa
Manager Cool Aroma SpaFlag for United Arab Emirates asked on
Dell* laptop battery
2 Comments2 Solutions15 ViewsLast Modified:
After fitting new Dell type battery to my XPS 13 the laptop would not power up. Disconnected and discharged the BIOS then laptop powered up OK, but after 2 or 3 hours a "Battery not recognised" warning came up then shutdown almost immediately. On restarting laptop all OK for another 2 or 3 hours then message and shutdown.
The battery was not an actual Dell but was the recommended equivalent with all the correct markings. Help!
EXPERT CERTIFIED SOLUTION
Dr. KlahnPrincipal Software Engineer
Unlock 2 Answers and 2 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
