hi,
We are using SQL server 2016 STANARD and we have index always defrag a lot daily, like 88% everyday, and we are using index rebuild script like:
-- Ensure a USE statement has been executed first.
SET NOCOUNT ON;
DECLARE @objectid int;
DECLARE @indexid int;
DECLARE @partitioncount bigint;
DECLARE @schemaname nvarchar(130);
DECLARE @objectname nvarchar(130);
DECLARE @indexname nvarchar(130);
DECLARE @partitionnum bigint;
DECLARE @partitions bigint;
DECLARE @frag float;
DECLARE @command nvarchar(4000);
-- Conditionally select tables and indexes from the sys.dm_db_index_physical_stats function
-- and convert object and index IDs to names.
SELECT
object_id AS objectid,
index_id AS indexid,
partition_number AS partitionnum,
avg_fragmentation_in_percent AS frag
INTO #work_to_do
FROM sys.dm_db_index_physical_stats (DB_ID(), NULL, NULL , NULL, 'LIMITED')
WHERE avg_fragmentation_in_percent > 10.0 AND index_id > 0;
-- Declare the cursor for the list of partitions to be processed.
DECLARE partitions CURSOR FOR SELECT * FROM #work_to_do;
-- Open the cursor.
OPEN partitions;
-- Loop through the partitions.
WHILE (1=1)
BEGIN;
FETCH NEXT
FROM partitions
INTO @objectid, @indexid, @partitionnum, @frag;
IF @@FETCH_STATUS < 0 BREAK;
SELECT @objectname = QUOTENAME(o.name), @schemaname = QUOTENAME(s.name)
FROM sys.objects AS o
JOIN sys.schemas as s ON s.schema_id = o.schema_id
WHERE o.object_id = @objectid;
SELECT @indexname = QUOTENAME(name)
FROM sys.indexes
WHERE object_id = @objectid AND index_id = @indexid;
SELECT @partitioncount = count (*)
FROM sys.partitions
-- 30 is an arbitrary decision point at which to switch between reorganizing and rebuilding.
IF @frag < 20.0
SET @command = N'SET QUOTED_IDENTIFIER ON; ALTER INDEX ' + @indexname + N' ON ' + @schemaname + N'.' + @objectname + N' REORGANIZE';
IF @frag >= 20.0
SET @command = N'SET QUOTED_IDENTIFIER ON; ALTER INDEX ' + @indexname + N' ON ' + @schemaname + N'.' + @objectname + N' REBUILD';
IF @partitioncount > 1
SET @command = @command + N' PARTITION=' + CAST(@partitionnum AS nvarchar(10));
EXEC (@command);
--PRINT N'Executed: ' + @command;
END;
-- Close and deallocate the cursor.
CLOSE partitions;
DEALLOCATE partitions;
-- Drop the temporary table.
DROP TABLE #work_to_do;
GO
how to make this script check the table name and if it sees that tables name , build the index of that table completely?
When the table defrags *daily* to that extend, then you need to review the reasons behind first.
And also evaluate the use of rebuilding the index.you mean drop unused index after review ?
, it’s important to know how to fix SQL Server index fragmentation if performance is suffering.we only rebuild the index of these 2 x tables when user complain.
IF @frag < 20.0
IF @frag >= 20.0
EXEC (@command);
It is just like in less than 1 hour the avg fragmentation in percent of that tables can go 50 %, and users will complain.This is an indicator for bad design.
I would consider a fixed job for rebuilding the index of that table without testing the fragmentation before.
does it need partition to avoid that?
Can you use filtered indices?
Without knowing anything about the process behind and the query pattern, you cannot trust the DTA.sure, someone suggest me to use it and I start not trusting that now.
Why does it fragment? I would really look into the clustered index first.I think I should drop that columnstore index, today is normal, fragmentation is normal, 7x % for the whole day.
CREATE TABLE [dbo].[PendingOrders](
[PlannedOrderID] [int] NOT NULL,
[PendingOrderID] [int] IDENTITY(1,1) NOT FOR REPLICATION NOT NULL,
[OrderID] [int] NULL,
[PatientID] [int] NOT NULL,
[IssueUserID] [int] NOT NULL,
[IssueDate] [datetime] NOT NULL,
[OrderCategoryID] [smallint] NULL,
[Continuous] [bit] NOT NULL,
[Comments] [nvarchar](1000) NULL,
[Warning] [bit] NOT NULL,
[Route] [smallint] NULL,
[PrevPendingID] [int] NULL,
[Status] [smallint] NOT NULL,
[GivenInPerKg] [smallint] NULL,
[PositionInSet] [smallint] NULL,
[PumpID] [int] NULL,
[RowOrderID] [int] NULL,
[LinkToOpenOrderID] [int] NULL,
[PatientWeight] [decimal](38, 14) NULL,
[LocationID] [smallint] NULL,
[CallerID] [uniqueidentifier] NULL,
[AttachedFormID] [uniqueidentifier] NULL,
[TS] [timestamp] NULL,
[Completion_status] [tinyint] NULL,
[CancelUserID] [int] NULL,
[CancelDate] [datetime] NULL,
[ConfirmSessionID] [int] NULL,
[ActionType] [smallint] NOT NULL,
[CancelledOrderID] [int] NULL,
[ValidationCoSign] [int] NULL,
[ValidationCoSignTime] [datetime] NULL,
[ValidationUserID] [int] NULL,
[ValidationTime] [datetime] NULL,
[CancelReason] [smallint] NULL,
[ReplacePendingID] [int] NULL,
[Duration] [decimal](38, 14) NULL,
[DurationUnitID] [smallint] NULL,
[TotalVolume] [decimal](38, 14) NULL,
[TotalVolumeUnitID] [smallint] NULL,
[UserLockIndex] [tinyint] NULL,
[LocksValue] [int] NULL,
[IvLineVolume] [decimal](38, 14) NULL,
[IsLinkedToPump] [bit] NULL,
[RateExcluded] [bit] NULL,
[History] [int] NOT NULL,
[OrignalTotalSolutionRate] [decimal](38, 14) NULL,
[AllergySecondSignature] [int] NULL,
[SecondApprovalSignature] [int] NULL,
[WasExported] [smallint] NULL,
[OrderRecordTS] [bigint] NOT NULL,
[PlannedHistoryID] [int] NULL,
[SecondApprovalDate] [datetime] NULL,
[MiscID] [int] NULL,
[LinkedToPendingID] [int] NULL,
[OriginalPendingID] [int] NULL,
[PatientWeightSignalDate] [datetime] NULL,
[DailyTotalVolume] [decimal](38, 14) NULL,
[DailyTotalVolumeUnitID] [int] NULL,
[DailyTotalVolumeUnitOfMessure] [tinyint] NULL,
[DailyTotalVolumeMode] [bit] NULL,
[PatientBSA] [decimal](38, 14) NULL,
[PrevPatientBSA] [decimal](38, 14) NULL,
[OrderingStyle] [smallint] NOT NULL,
[DoseFormID] [smallint] NULL,
[TemplateID] [int] NULL,
[TotalSolutionDripUnitID] [smallint] NULL,
[PreparationStatus] [tinyint] NOT NULL,
[PreparationCoSign] [int] NULL,
[PreparationCoSignTime] [datetime] NULL,
[Dose] [decimal](38, 14) NULL,
[DoseDripUnitID] [smallint] NULL,
[AdministrationDetailsId] [int] NULL,
[LockerTemplateId] [smallint] NULL,
[LockerTemplateState] [nvarchar](max) NULL,
[OrderActionId] [int] NULL,
[DoseGuid] [uniqueidentifier] NOT NULL,
[UpdatedSectionId] [int] NULL,
[DoseUpperRange] [decimal](38, 14) NULL,
[DurationUpperRange] [decimal](38, 14) NULL,
[OrignalTotalSolutionRateUpperRange] [decimal](38, 14) NULL,
[DailyTotalVolumeUpperRange] [decimal](38, 14) NULL,
[TitrationMode] [bit] NULL,
[DoseLowerRange] [decimal](38, 14) NULL,
[DurationLowerRange] [decimal](38, 14) NULL,
[OrignalTotalSolutionRateLowerRange] [decimal](38, 14) NULL,
[DoseRangeDripUnitId] [smallint] NULL,
[DurationRangeUnitId] [smallint] NULL,
[TotalSolutionRangeDripUnitID] [smallint] NULL,
[PatientWeightType] [smallint] NOT NULL,
CONSTRAINT [PK_PendingOrders] PRIMARY KEY CLUSTERED
[PendingOrderID] ASC
)WITH (PAD_INDEX = ON, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON, FILLFACTOR = 80) ON [PRIMARY]
) ON [PRIMARY] TEXTIMAGE_ON [PRIMARY]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrd_Continuous_1__11] DEFAULT ((0)) FOR [Continuous]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrd_Warning_2__11] DEFAULT ((0)) FOR [Warning]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrd_PrevPending1__12] DEFAULT ((0)) FOR [PrevPendingID]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_GivenInPerKg] DEFAULT ((0)) FOR [GivenInPerKg]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_PositionInSet] DEFAULT ((0)) FOR [PositionInSet]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_RowOrderID] DEFAULT (NULL) FOR [RowOrderID]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_Completion_status] DEFAULT ((0)) FOR [Completion_status]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_ActionType] DEFAULT ((0)) FOR [ActionType]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_CancelReson] DEFAULT ((0)) FOR [CancelReason]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_RateExcluded] DEFAULT ((0)) FOR [RateExcluded]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_History] DEFAULT ((0)) FOR [History]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_WasExported] DEFAULT ((0)) FOR [WasExported]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_OrderRecordTS] DEFAULT ((0)) FOR [OrderRecordTS]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_PlannedHistoryID] DEFAULT (NULL) FOR [PlannedHistoryID]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF_PendingOrders_PreparationStatus] DEFAULT ((0)) FOR [PreparationStatus]
GO
ALTER TABLE [dbo].[PendingOrders] ADD CONSTRAINT [DF__PendingOr__Patie__518D3740] DEFAULT ((0)) FOR [PatientWeightType]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_DoseDripUnits] FOREIGN KEY([DoseDripUnitID])
REFERENCES [dbo].[DripUnits] ([DripUnitID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_DoseDripUnits]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_DripUnits] FOREIGN KEY([TotalSolutionDripUnitID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_DripUnits]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_DurationUnitID_Units] FOREIGN KEY([DurationUnitID])
REFERENCES [dbo].[Units] ([UnitID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_DurationUnitID_Units]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_FB_FORMS] FOREIGN KEY([AttachedFormID])
REFERENCES [dbo].[FB_FORMS] ([FormID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_FB_FORMS]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_LockerTemplateId] FOREIGN KEY([LockerTemplateId])
REFERENCES [dbo].[ORD_LocksTemplates] ([LockerTemplateID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_LockerTemplateId]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Ord_Reasons] FOREIGN KEY([MiscID])
REFERENCES [dbo].[Ord_Reasons] ([ID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Ord_Reasons]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_OrderCategories] FOREIGN KEY([OrderCategoryID])
REFERENCES [dbo].[OrderCategories] ([OrderCategoryID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_OrderCategories]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_OrderEntry_LinkToOpenOrderID] FOREIGN KEY([LinkToOpenOrderID])
REFERENCES [dbo].[OrderEntry] ([OrderID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_OrderEntry_LinkToOpenOrderID]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Orders_DoseForms] FOREIGN KEY([DoseFormID])
REFERENCES [dbo].[Orders_DoseForms] ([DoseFormID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Orders_DoseForms]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Orders_Locations] FOREIGN KEY([LocationID])
REFERENCES [dbo].[Orders_Locations] ([LocationID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Orders_Locations]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Orders_Routes] FOREIGN KEY([Route])
REFERENCES [dbo].[Orders_Routes] ([RouteID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Orders_Routes]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Patients] FOREIGN KEY([PatientID])
REFERENCES [dbo].[Patients] ([PatientID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Patients]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_PlannedHistoryID] FOREIGN KEY([PlannedHistoryID])
REFERENCES [dbo].[PlannedOrdersHistory] ([PlannedHistoryID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_PlannedHistoryID]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_PlannedOrders] FOREIGN KEY([PlannedOrderID])
REFERENCES [dbo].[PlannedOrders] ([PlannedOrderID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_PlannedOrders]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_TotalVolumeUnitID_Units] FOREIGN KEY([TotalVolumeUnitID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_TotalVolumeUnitID_Units]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Users_AllergySecondSignature] FOREIGN KEY([AllergySecondSignature])
REFERENCES [dbo].[Users] ([UserID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Users_AllergySecondSignature]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Users_CancelUserID] FOREIGN KEY([CancelUserID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Users_CancelUserID]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Users_IssueUserID] FOREIGN KEY([IssueUserID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Users_IssueUserID]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Users_PreparationCoSign] FOREIGN KEY([PreparationCoSign])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Users_PreparationCoSign]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Users_SecondApprovalSignature] FOREIGN KEY([SecondApprovalSignature])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Users_SecondApprovalSignature]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Users_ValidationCoSign] FOREIGN KEY([ValidationCoSign])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Users_ValidationCoSign]
GO
ALTER TABLE [dbo].[PendingOrders] WITH NOCHECK ADD CONSTRAINT [FK_PendingOrders_Users_ValidationUserID] FOREIGN KEY([ValidationUserID])
NOT FOR REPLICATION
GO
ALTER TABLE [dbo].[PendingOrders] CHECK CONSTRAINT [FK_PendingOrders_Users_ValidationUserID]
GO
Did you test compression?
Is the clustered index the only index?
Cause sometimes defragmented indices are better left untouched.
