IBMi : Command /QSYS.LIB/QJVATOOLS.PGM not found
Hi Experts,
I tried to run a QSHELL java command and get this error:
exec: 001-0014 Command
…Hi Experts,
…IBM 5250 Emulation. How do I run a macro when a session is started which contains my credentials.
We are trying to replace RUNRMTCMD with STRPCCMD and the DOS verbiage keeps being an issue.
Without
…I am getting the following error with my yum repo on the iSeries:
[Errno 14] curl#60 - "SSL
…Hi Experts,
While using IBM's WSDL2RPG, I processed an wsdl with the following result:
Hi Experts,
I need a program to translate/export a Data Structure into XML-file (or variable).
For
…Hi Experts,
I have an RDi problem with one of the IBM-i's I have to connect with.
When I connect to
…We are in research of IBM QRadar XDR installation.
We need the following information to proceed
…I'm trying to use a SQL stored procedure to call a CL program on the iSeries.
CREATE OR REPLACE
…I need to create a program that retrieves a list of virtual devices and then delete those devices
…I am working on an RPGLE program that include Compiler Directives that I have never seen before and
…alternatives for the below listed software with less cost effective
BMC Mainframe: Mainframe computer
ASG Smart Suite: Integrated
…Does anyone have a good way of running a remote command on iSeries servers where you have to use a
…Sysplanar Errors
SRC : A7004761
Description : Firmware Update Key has expired
Power 8 , IBM, 8284-22A
