Explore Switches / Hubs on Experts Exchange
Switches / Hubs
A switch is a device that filters and forwards packets of data between LAN segments. Switches operate at the data link layer or the network layer o...
Read more
  • 22K Content
  • 8.3K Contributors
Expert Spotlight
Network Architect and EE TA
Over 15 years' experience in enterprise network design and implementation focused on routing, switching, Wi-Fi and Cisco ISE.
Advice Question
ISE Deployment Policies for Wired & Wireless Endpoints
Hello Experts,
We're currently in the process of rolling out ISE policies for our corporate
Troubleshooting Question
not able to ping devices on the same switch or from my core switch
byDan
8
I created a new vlan on switch sw51, and assigned 4 ports on the switch to the new vlan.
I plugged in
Advice Question
Network Options/Settings Best Configuration
I'd appreciate guidance on how to set some of the options/settings on the Ubiquiti networking
Aruba switch credentials issue.
We have an HP Aruba J9772A, 2530-48G-PoEP switch.  As far as I can tell, it's running YA.16.10.0001.
Help network engineer to configure cisco router/switch via API
byeemoon
Hi Anyone can talk a little about how API /Python to help network engineer to configure cisco
Configuring multicast on VLAN or access mode port (for spesific vlan)
I have a Cisco switch 9300 which has multi VLAN (one of them is VLAN 20). I have AP400 (NEC)
Network Interruption
8
Every day I have packet loss to a switch. Between 5pm and 6:30 pm. Sometimes as far out at 7 pm.
I
CISCO ISR 4321 Config assistance
7
I have inherited a CISCO ISR 4321 that acts as a handoff device between the ISP and the edge
WS-C2960X-48FPD-L %PHY-4-SFP_PLUS_NOT_SUPPORTED: The SFP PLUS in Te1/0/2 is not supported
5
Switch WS-C2960X-48FPD-L - 15.2(7)E3 - C2960X-UNIVERSALK9-M
Cable DAC Qnap SPF+ don't work
done
100G interfaces problem on cisco ASR 9006
11
Hi ,
I have problem on Cisco ASR 9006 4 Line Card , recently we have installed new A9K-2x100GE-SE
cisco switch sending logs using wrong IP address
byDan
11
I am testing 2 different syslog servers, loggly and SW SEM, and I found an issue on my core switch.
Advice Question
802.1X monitor mode in JunOS (EX series switches)
Hi Experts,
I am deploying 802.1X on Juniper EX switches and generally it works fine, except there
Dell Connectrix DS-6620B SAN switches login
  • I just bought Dell Connectrix DS-6620B SAN switches. OS version is 8.2.3.
  • On my laptop, I installed
Advice Question
setup two S4148-ON switches for vSAN and vMotion using tagged vlans and vlan
12
Hello Everyone. I have two S4148F-ON switches that I would like to setup a couple vlans, vlt,
syslog server that displays the errors summarized, or grouped by switch.
byDan
8
I am looking for a easy to use, but robust syslog server, could be hosted in the cloud or on prem.
1 switch notprsnt in virtual-chassis
byJ G
After unexpected reboot, show-virtual chassis on a juniper ex2200 shows 1 of the for swtiches is
cisco 9300 switch Layer 2 traffic limitation
bySam P
in this scenario, I am expecting video stream traffic from few ports on switch C9300-48UXM.
we are …
Arista 7060CX2-32S  set ports 24-32 as 4 x 25g to use breakout cables.
I have an Arista 7060CX2-32S and I want to set some of the ports to 4 x 25g mode with a QSFP to 4 x
aruba
Does any know why an Aruba switch would see a high number (and increasing) of lldp neighbor get
Unifi Layer 3 traffic monitoring
I’ve just finished an upgrade to a full Unifi network.
Firewall - UXG-Pro
Switches - All Layer 3
Get Answers
Join a Group Discussion
Collaborate
Monitor your Site
Explore solutions and more
