How to investigate and fix system startup problems using Paragon Rescue Kit Free
Posted on
5,343 Points
3 Endorsements
Last Modified:
Published
Experience Level: Beginner
5:13
In this Micro Tutorial viewers will learn how to use Boot Corrector from Paragon Rescue Kit Free to identify and fix the boot problems of Windows 7/8/2012R2 etc. As an example is used Windows 2012R2 which lost its active partition flag (often happens during backup restore or disk swap or wrong installation)
Author:noxcho
0 Comments
Natural disasters, technical faults, human error—these are just a few factors that leave your IT systems vulnerable to failure. To ensure incidents like these don’t catch you off guard or put your team offline, emergency planning is a must.
In this article we will show you HOW TO: Backup (Export) and Restore (Import) virtual machines to VMware vSphere Hypervisor 7.0 for FREE. This procedure can be followed to backup (export) and restore (import) any virtual machine hosted on the VMware…
