This video shows how to set up a shell script to accept a positional parameter when called, pass that to a SQL script, accept the output from the statement back and then manipulate it in the Shell.
Thanks for information very useful.
In the sameway can you please create a simple video which runs a procedure and store the output of the procedure in shell script to proceed further.
Not quite sure what you're looking for. You want to call a stored procedure that returns a value and then that value is captured in the shell script instead of the return value from the query as shown in the video ?
This article shows how to force SQL and Web Developers to not use SA account while other services are already deployed to connect to SQL Server via SA account. So we will not touch existing services and applications only developers must be prevented.
A clarification of some common doubts about DBCC CHECKDB for Database Administrators. Includes estimated times to repair database corruption's in production databases.
