This video shows how to set up a shell script to accept a positional parameter when called, pass that to a SQL script, accept the output from the statement back and then manipulate it in the Shell.
Thanks for information very useful.
In the sameway can you please create a simple video which runs a procedure and store the output of the procedure in shell script to proceed further.
Not quite sure what you're looking for. You want to call a stored procedure that returns a value and then that value is captured in the shell script instead of the return value from the query as shown in the video ?
After looking into a question at EE, a thought came to my mind that I considered would make a good article. "Transform Text copied from Excel Table into Real Table in SQL" as it is totally possible to do. Here's the result.
